SWL RX ANTENNA HELP NEEDED
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
Would a AM PRO antenna mounted quite high be any good for just RX on the sw bands if so which one should i buy ? radio is a AOR AR-3000A , It seems to be quite a decent receiver just need a decent antenna to use with it any thoughts please
Re: SWL RX ANTENNA HELP NEEDED
Post by paulears »
Short wave? What do you want to listen to? I had to look am pro up , to discover it's a make - so looking at them, they seem to all be HF aerials, so that's what you're after? They also seem to be mostly mobile types, so not much use up in the air? Perhaps a long wire, or simple dpole, or something else would be better - and much cheaper to experiment with.
Post by Admiral »
I have AMPRO mobile antennas, but for just that, mobile, their coil is generally as long as the whip, so they are a compromise for TX/RX to save me having 40 metres of wire hanging off of my car, homebase they'll work for RX, but not as well as a dirty great run of cable.
nay27uk
Post by nay27uk »
I would recommend a simple SWL Magnetic Loop antenna.
I made mine some time ago now and although only used indoors it works fantastic because it is tunable also.
Mine is 1 meter wide with the feed loop being about 13" both loops made from 10mm Copper Tubing.
Just google SWL Magnetic Loop Antenna I got my idea from THIS SITE but mine is made differently, mine sits on top of a wooden box that houses an Air Variable Capacitor, my loops can be rotated by 360 degrees by hand.
see picture for better understanding.
That website should give you a rough starting point though.
M6LIG / 2E0LIG / 26TM1995
Baofeng UV5R+
Boafeng RD-5R
Malahit SDR - Ground Loop
Panasonic DR28-LBE
Post by ch25 »
Any wire dipole or loop antenna will outperform Ampro.
Bernie
Post by Admiral »
ch25 wrote:Any wire dipole or loop antenna will outperform Ampro.
Bernie
Yes, as a base antenna, but as a mobile antenna then AMPRO perform very well for the money, I have several, and our friends at Moonraker stock the full range.
GRUBSCREW
Call Sign: G7WFB
Post by GRUBSCREW »
I have a G Whip receive build quality is fantastic you don't need a ATU (Preselector) I Iive
in Spain most mornings listen to the Australian nets I have a few receivers works well with all of them.
Been a SW Listener for Sixty Years tried most antennas with this one put it up and listen to the world.
John
WARLOCK
Call Sign: 26TM134
Post by WARLOCK »
HI GRUBSCREW which G Whp are you using as i have been on there site and they do so many antrnnas ?
GRUBSCREW
Call Sign: G7WFB
Post by GRUBSCREW »
Hi they do a receive antenna just look for that.
