Tango Mike Membership Requests 2016
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: Tango Mike Membership Requests 2016
Back from Holiday today, so will get on this when I get a moment :-)
- MrWeetabix
- Admin
CBR1100XX wrote:Could I please have 108-TM-127
Paul, Highlands
Edd200sx wrote:edd (norchip)
Hants
26TM 9966
Hello Chaps,
I have allocated both of these new callsigns, and they will be updated on the Tango Mike main website shortly too, but you may start using them straight away. Cheers Much and welcome to Tango Mike!
108-TM-127 - Paul (CBR1100XX), Highlands
26-TM-9966 - Edd (Edd200sx), Norchip
73 de Craig
- Call Sign: 108TM127
Cheers Craig , much appreciated .
DELETE MY ACCOUNT
- Call Sign: 26TM1952
Hi my name is Graham (gray21) I live in clacton on sea Essex uk . Can I please have 65 Tm 1952 as a call sign please . Thanks Graham
- MrWeetabix
- Admin
Hello Graham,
26 TM 1952 is free, but unless you live in Sierra Leone, 65 TM 1952 probably isn't any good to you
Here in the UK we have several country codes, England is 26, Scotland is 108, Wales is 163, Northern Ireland is 68 and Ireland is 29.
Please confirm that you're happy to have 26TM1952 and we'll rubber stamp that for you :-)
Yes that is ok thanks for your help gray21MrWeetabix wrote:Hello Graham,
- MrWeetabix
- Admin
No worries Graham,
I have allocated 26-TM-1952 for you and you may start using this immediately.
If you require a PO Box, we have one available which is a one-off 37, with lifetime usage and re-directs (fair usage applies)
See Here - http://www.transmission1.eu/viewtopic.php?f=27&t=12857
We also have new QSL cards available, should you need them.
See here - http://www.transmission1.eu/viewtopic.php?f=27&t=51394
Thanks, and welcome to Tango Mike
26-TM-1952 - Graham (Gray21), Clacton-On-Sea
- harakiri
My name is Tore from Norway
If I could get like 20 TM 1984 I would love that. And will use it right away.
Many thanks.
-H
Many thanks.
-H
Eh..Its time.
- Call Sign: 108TM309
Hi,
Pete
Glasgow, Lanarkshire, Scotland
Requesting 108-TM-309
Cheers, Pete
Pete
Cheers, Pete
- MrWeetabix
- Admin
Hello Pete. Your callsign has been allocated and you can start to use it straight away :-)AlbaDX wrote:Hi,
Pete
Cheers, Pete
108-TM-309 - Pete (AlbaDX), Glasgow
Hello Tore, Your callsign has also been allocated and can be used immediately.harakiri wrote:My name is Tore from Norway
Many thanks.
-H
20-TM-1984 - Tore (harakiri), Norway
If either of you need QSL cards, we have some new ones in stock...
Thanks and welcome to Tango Mike!
Hi. Could I have TM 956 if it's available? If not just allocate me the next available number. Many thanks. Jeff ( Night Watchman
I think I posted my first request for a callsign in the wrong section. Sorry mods! Could I have TM 956 if possible? I am in Dorset UK. If that number has been allocated then any one will be fine.
Thanks in advance.
Jeff ( Night Watchman )
Thanks in advance.
- 14TM056
- Call Sign: 14TM056
Welcome and good choice.
73's Paskal ..
14TM056
73's Paskal ..
14TM056
