I am building a loop antenna and have just got an amplifier kit that can do several antenna configs. You have to make up the switch box, but at the moment I only want to run a single loop. I don't have the switches yet but i think he got the instructions wrong. It says you need two SPST switches but the photo diagram down the page shows what looks to me like SPDT switches.
Anyway as I only want to run a single loop (loop A) for the moment can anyone tell me if I can do this by just bridging the connector pins so that it's just stuck in loop A config. ?
What pins would i need to connect for loop A only.
Look at 2.5 Mode Control Switches
Here are the instructions. http://active-antenna.eu/tech-docs/2_Ac ... unt_20.pdf
Help needed with amplifier switch config
- Warden
- Call Sign: 26TM612
26-TM-612
No one rules if no one obeys.
Winner of the amazing In before the lock game 09/09/14
- Banned
Re: Help needed with amplifier switch config
I'd just link pins 4 and 6 together, and not bother with the switches at all.
Edit: Oops. Try 3 and 6. you're using a loop aren't you ... not a dipole.
- Warden
Cheers got it up and running but needs work, not performing as good as my dipole yet.
26-TM-612
- Banned
In what way?Warden wrote:Cheers got it up and running but needs work, not performing as good as my dipole yet.
Don't forget that loops work much better if you put a big piece of black tape over the 'S'-meter
- Warden
S/N is not as good, and if i turn the loop in a certain direction the noise floor goes mad and i just get broadcast stations.
I made a dipole from a Diamond BU-50 1:1 balun while waiting for the kit to arrive and it's working a treat. I was advised to get this kit when the receiver would not work on my Gwhip Mini Widebander due to clipping errors popping up all the time.
Will have to experiment a bit more with loops but not sure it's going to match the dipole. These direct sampling receivers don't half seem fussy when it comes to antennas.
26-TM-612
- Banned
A good dipole is just fine.Warden wrote:S/N is not as good, and if i turn the loop in a certain direction the noise floor goes mad and i just get broadcast stations.
All I use for recieve on all bands is a balanced inverted 'V' about 25 feet long, with the middle right up inside the loft apex, and 75 Ohm satellite coax.
Does the job.
