Can you pick up a radio wave 185 miles from source over sea
4yorks
Post by 4yorks »
I have been to Dover, then a small village called St Margaret's at Cliff near Dover and I was able to pick up French Mobile phone networks and French radio stations. ( I was even able to make a call on the French Network )
Recently I was in Hollyhead, Wales and I could pick up Irish Radio stations in my car and my phone could see Irish mobile phone networks ( O2 Ireland, Vodafone Ireland) as well as the normal UK ones, but I couldn't connect for some reason.
I've noticed that on the Shetland islands to Norway is 180 miles. Would it be possible if you're on a high cliff , to pick up radio station and Mobile networks over that distance. or impossible? how about AM.
Thanks! :D
Martinedwards
Re: Can you pick up a radio wave 185 miles from source over
Post by Martinedwards »
"a" radio wave?
yup, worked california on 40m last night.
Phone freqs?
maybe.....
maybe not!
ChrisCSL
Banned
Banned
Post by ChrisCSL »
The people on the Kent coast have been moaning about this for a while. They get hit with roaming charges for local calls.
http://www.dailymail.co.uk/news/article ... -KENT.html
I know if I used to go over on a Booze Cruise, my phone turned French just as soon as we cleared Dover harbour. I think that across the North Sea to Nogland might be pushing it though.
bigpimp347
Post by bigpimp347 »
regularly work the USA on my CB radio :)
acl777
Post by acl777 »
Yep, I live in Norwich and regularly pick up Dutch,Belgian, French and German FM radio. As far as AM transmissions go I often pick up stations from the US during the winter months.
RogerD
Post by RogerD »
4yorks wrote:Recently I was in Hollyhead, Wales and I could pick up Irish Radio stations in my car and my phone could see Irish mobile phone networks ( O2 Ireland, Vodafone Ireland) as well as the normal UK ones, but I couldn't connect for some reason.
Getting a strong signal isn't the whole story, for connecting. There's a time limit for how your phone's signals can fit into the time-sliced communications system. If you're too far away, the limitations of the speed of light/radio means that your signal can't sync up properly with the base station before the next cycle of digital pulses. It's something like 35km for GSM IIRC
acl777
Post by acl777 »
Very interesting RogerD. I had no idea this was the case. I'm guessing if mobile phones were analogue it would be as simple as a strong signal.
RogerD
Post by RogerD »
That's right.
More details here http://en.wikipedia.org/wiki/Timing_advance
SecretShortwave
Post by SecretShortwave »
you often get enhanced propagation other sea paths at vhf and uhf for many different reasons ducting is the most common reason
due to temperature inversions which are more common over sea paths, this creates a pipeline which gives a ideal medium for radio waves to travel in
but can be very localised a guy 2 or 3 miles inland may be hearing nothing. With practice you can get pretty good at predicting when this is going
to occure your self, any time you have fog or mist is a good sign temp inversion is taking place so there is a good chance of some ducting also dawn and dusk
due to the different layers warming up and cooling down at different rates.Type tropospheric ducting into google for a much better explanation. You also get enhanced prop at HF over a sea path due to water being a better reflecting medium than land for radio waves
acl777
Post by acl777 »
RogerD wrote:That's right.
Thanks for the link.
acl777
Post by acl777 »
SecretShortwave wrote:you often get enhanced propagation other sea paths at vhf and uhf for many different reasons ducting is the most common reason
Yes I know what you mean. I think tropospheric propagation is the most compelling of all.
26TM800
Call Sign: 26TM800
Re: Can you pick up a radio wave 185 miles from source over sea
Post by 26TM800 »
185 miles is nothing for *MW or FM but is asking a lot for phone.. but
keep watching this map and try it :-)
http://www.dxinfocentre.com/tropo_nwe.html
consider getting a cheap phone hacking off the aerial and soldering on a 915mhz yagi off ebay
similar discussion here may be of use: http://skywavesdx.org/viewtopic.php?f=53&p=7932#p7932
good info about the timing problem, that may explain why despite the fact that my Phone often locks onto Irish networks in Wales I can never text or call with them
*when NRK Kvitsoy 1314 was still on it covered most of the UK in daytime
my nearest and most regular Norwegian FM tx is Bokn 97.3 873km away I hear it a few times every year on tropo here in East Cheshire
26TM800
Call Sign: 26TM800
Post by 26TM800 »
SecretShortwave wrote:. You also get enhanced prop at HF over a sea path due to water being a better reflecting medium than land for radio waves
definitely, I've noticed the MUF is consistently higher at the coast,
if 10 meters is marginal at home it will be open on the North Wales Coast
kr0ne
Post by kr0ne »
26TM800 wrote: consider getting a cheap phone hacking off the aerial and soldering on a 915mhz yagi off ebay
I haven't seen a mobile phone you could hack the aerial off since the 1980s!
Post by Admiral »
26TM800 wrote:185 miles is nothing for *MW or FM
Schoolboy error, quoting frequencies and modes as the same thing.
185 miles across icy seas, around 1Ghz on 1w, with an internal antenna the size of a hair grip? In the real World, I say no chance.
But you never know.
