And Albrecht etc.
This is not a review, just some initial thoughts on this device.
Cons.
Audio is poor, speaker could do with being in the top lid.
err, that's it
Pros
Cheap, Moonraker.eu of MK are selling at £69.96
Compact
All accessories provided, home AC unit, mobile fag lighter 12v unit, and open ended 12v lead, telescopic antenna and a window mounted wire antenna with co-ax and BNC connector and mounting bracket with thumb screws.
Very simple to use
Close Call
It is marketed as a homebase unit, but realistically it ain't. For me the appeal is the simple use which makes it an ideal mobile set.
Analogue scanning is on its arse, so RF-snagging is a must in the dying embers of the hobby, Close-call for less than 70 quid cannot be ignored.
Uniden UBC355CLT
Uniden UBC355CLT
- radiosification
Re: Uniden UBC355CLT
Literally everything here in London is digital now, and close call doesn't pick up and TDMA signals. So if you live in London like me, its a bit pointless having close call.
- rocket
- Call Sign: M0ROC
Not being able to program the 355CLT memory channels for civil airband is a downside.
73 de Mark
M0ROC, 26HB896, 26TM896
M0LGC (Letchworth Garden City Amateur Radio Society)
Flightradar24 live feed: T-EGGW38 via AirNav RadarBox 3D
rocket wrote:Not being able to program the 355CLT memory channels for civil airband is a downside.
Not being made of solid gold is a downside too, but it's 70 quid. It's designed to be primarily factory pre-programmed, that's the appeal for mobile use.
It is what it is, a very cheap set with CloseCall with a small footprint.
- radiosification
Well I think it's an upside actually! If it was made of solid gold you'd be sure to get robbed anytime you took it out of your home! Plus it would cost a hell of a lot more, and solid gold is not that hard either so it would probably bend if you held it too tight.
- billybigears
Hi new to scanning and I recently bought myself ubc355clt as wasn't sure what one to buy could you tell me what I would get with I higer spec? Than I get out of this. Didn't want to spend to much am I missing out on alot? Keeping this any info would be much appreciated cheers
