Hi all not been on for a while but have some questions regarding DDS Signal generators.
Just found this on eBay and it says it is 0-40Mhz.
Questions are
1) Can it be used to tune HF receivers
2) Can it be modulated
3) How the hell do you use it
http://www.ebay.co.uk/itm/1pce-DDS-Sign ... 53fa41fc44
DDS Sig gen Question
- nay27uk
M6LIG / 2E0LIG / 26TM1995
Baofeng UV5R+
Boafeng RD-5R
Malahit SDR - Ground Loop
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- Andy
Re: DDS Sig gen Question
It looks like it needs to be controlled by a serial or parallel bus from a PC. Not sure what software would be needed. Also the output will be at a fairly high level and you'll need a calibrated attenuator to get sensible results from it.
'SOMEONE GET ME A SAW!'
Andy.
Andy.
- Andy
- kr0ne
You need a microcontroller, or similar, to control it.
They give a reasonably good signal, but normally require a buffer amp of some sort to be usable.
They're actually really easy to get going if you're familiar with microcontrollers. If not, take a look at the Arduino platform - it's a really easy (and quick) way to get started with microcontrollers.
http://arduino.cc/
http://www.ebay.co.uk/itm/Arduino-UNO-R ... 27d380f981
http://arduino.cc/
- mattltm
Add one of these and you have a complete 0-30MHz VFO & Signal Generator, maybe!
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1217439093
"Spooky action at a distance."
- nay27uk
Cheers for the replies guys.
mattltm are you saying add that and the one I posted a link to on the baord that kr0ne posted a link to
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
Baofeng UV5R+
Boafeng RD-5R
Panasonic DR28-LBE
- M0KRL
- Call Sign: M0KRL
If you need ideas of how to implement these DDS modules just search for the VK5TM website. He has sample code for a PIC chip as well as PCB layout designs. I have built one based on his designs and it works great with tuning step select from 1hz upto 1mhz, with both sine and square wave output and LCD display, as others have said, the module needs buffering for a lot of purposes, but just as a signal source upto the top of the HF bands, and usable harmonics above, you can't beat them for the price. Karl
Whoever suggested repair by replacement, should be repaired by replacement!!!
Yaesu FT-100, Uniden 2830 (converted to 4Mtr multimode),Trio TR7800 (2Mtr FM), Yaesu FT7100M (2/70 FM) Baofeng UV5R (2/70 FM), Weierwei V1000 (2Mtr FM), Key KME80 (4mtr FM)
- kr0ne
Sorry - missed this... I think the link mattltm posted is a standalone thing, so you would just add the DDS module and some other components.nay27uk wrote:mattltm are you saying add that and the one I posted a link to on the baord that kr0ne posted a link to
There are also complete (built) units available fairly cheaply on eBay that use the same modules inside.
