Hi can anyone help me as I am trying to use the DSD software and locate some Mototrbo frequencies in my area in order to make sure I have the software set up correctly but alas I am having no luck.
I have found DRM in and around the 160Mhz ranges but most of the decode seems to be data only and no voice communications. So any information you have would be appreciated
DMR Mototrbo in and around Carlisle area
Do not believe everything that is in black and white.
Oh and prestigious Winner of "In Before The Lock June 2014"
Flex 5000A, Trio TS-830S, Icom IC-E2820, IC-E92D and a DVB-T SDR Dongle
- iansradios
Re: DMR Mototrbo in and around Carlisle area
Who are using trbo vhf in carlisle,i go up there quite often and it still the same old analogue users? only one trbo user i know of.
I thought that would be the case but still worth asking.
