Differences between PB-010AA and PB-010AB ?
- cb4ever104
Hi All .
That's the question . Anyone have the answer ?
Sammy
Sammy
Re: Differences between PB-010AA and PB-010AB ?
Can't answer the question but i was always led to believe the AA version
was a tad better, i will leave the technical part to those who know why if
thats the case.
thats the case.
- 14CS06
Hello Sammyssjenkins wrote:Hi All .
Sammy
The answers are here
PThe PB-010AA Chassis was the First Cobra 148 GTL-DX MK2 version produced. There are a few notible differences between the AA and AB Chassis. The below picture is of a 010AA Chassis, notice how the 3 tuning pots VR3, VR4 & VR6 are all orientated the same way round.
http://www.cobraworxshopz.com/cobra_148gtl-dx_13.html
Claude
- George EI7KO
- Call Sign: EI7KO
Lol.....cobbledtogetherfcukedupslopz. What would he know????
BLUE LED'S ARE BEST!!!!
FACEBALLS GROUP: https://www.facebook.com/groups/irishcustomradios
YOUTUBE CHANNEL: https://www.youtube.com/channel/UC4aXkT ... wszD8E68Dg
Depends what mode your talking about if eprom'd... standard all the way if for a mk1 aa board if for ssb! i mean front end on a mk1 is well known to be sensitive standard i never liked the delay in a mk 1 when converting beep to on/off! - just for starters!
- cb4ever104
The mkII has the PB-010 . The Superstar 360s I have allhave the AB variant and I was just wondering what the difference was between them .warhorse wrote:Depends what mode your talking about if eprom'd... standard all the way if for a mk1 aa board if for ssb! i mean front end on a mk1 is well known to be sensitive standard i never liked the delay in a mk 1 when converting beep to on/off! - just for starters!
Sammy
- 163TM847
The front of the board differs slightly from AA to AB, IE: Beep circuit but apart from that not much else at all.
I have seen a few AB's where both sets of crystals are present with 6 tuning inductors, But not for a long time.
What do you mean, Got me a bit lost there.warhorse wrote:i never liked the delay in a mk 1 when converting beep to on/off!
From what i remember after the beep mod the dekey is still there but no beep just like its still going through the switching ~ cycle! never noticed that in a mk2 Ab board!
- 163TM847
Then its being switched wrong, I have seen it done before in the PC-879AB where one leg of TR33 is switched to ground which only mutes the beep tone, Simply switching the one leg of C146 [beep timer] will knock the beep off completely with no delay.warhorse wrote:From what i remember after the beep mod the dekey is still there but no beep just like its still going through the switching ~ cycle! never noticed that in a mk2 Ab board!
- cb4ever104
Thanks Nick . That's good to know .Black Spirit wrote:The front of the board differs slightly from AA to AB, IE: Beep circuit but apart from that not much else at all.
Sammy
