Im looking for a standalone bluetooth module that will connect to a bluetooth headset with an audio in and out. I dont mind modifying but has to be cheap. So i can try using my helmet intercom with the radio.
I was trying to find the Jabra A210 but it doesnt seem to exist in the UK, its what the americans are using
http://www.jabra.com/sites/Jabra/GNImag ... EN_678.pdf
Any ideas?
Bluetooth adaptor
- DX-Digger
- Call Sign: TM205
Re: Bluetooth adaptor
I got mine off ebay, however the batteries in them dont last very long I found i was forever charging it up,and the casing easily came apart so needed to be taped up. although when it worked i got excellent audio reports. I also modified the blue tooth earpiece I had and added a long boom arm with electret mic at the end. much less wind noise.
Found some on link below
http://electronics.pricegrabber.co.uk/m ... 19889.html
HTH Mark
EDIT: sorry just spotted none were available.
HTH Mark
I will probably wire the whole thing up to take power from the bike. Easier that way.
Looking for something identical to that but like i say you cant buy them for love nor money.
- DX-Digger
- Call Sign: TM205
Hmm Wonder if one of the later models uses the same printed circuit board, maybe you could rewire it?
I would be happy to take a photo of the insides of my unit for you to compare.
Just let me know. The main problem with bluetooth headsets under a fullface helmet is after a while your ear starts to hurt.
Although I believe that some helmets now come with the foam cut out for a bluetooth head set, Im sure I saw one a while back.
Anyway I hope you manage to find one or something suitable. let me know if you need any pictures etc.
i have a proper helmet intercom. It mounts on the outside with a boom mic and speaker that velcros inside.
- GW0DIV
- Call Sign: GW0DIV
How about this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
http://www.facebook.com/southwalesradio
http://www.radioclubs.net/rars/
Twitter: @GW0DIV
President of Bristol Channel Repeater Group
Twitter: @GW0DIV
If u are still looking - i found this:
http://www.maas-elektronik.com/Bluetoot ... ete.1.html
At the mikrophone u can connect an aditional earpiece or so.
The transceiversite equipment has factory default connectors, but u can
take anyone, thats availiable, and adapt it to ur needs...
There are zwo different sets: low and high power. the hp-set works here til inside
the neighbours house - 30 meters away.
73
codebreaker
73
codebreaker
Too expensive mate and looks big. I want something i can strap to the back of a handy. Cheers for the suggestion though.
