Faults with a Ham international Multimode 2
- Raverrst
- Call Sign: 26LW29
Hi guys. As in title I’ve a Ham international multimode 2 PTBM059COX board, bought as none working, someone had converted it to 10meters as the crystals had been changed, iv bought a 2nd sub board fitted the correct crystals, started doing the alignment and I can’t get the vco voltage to adjust down (4.6volts beleave it should be 3.6volts) ajusting the core makes no difference to the voltage at all, iv changed the vco but still no change? The Rig will tx on all three bands but only on one frequency and this rafts badly! Channel changer makes little to differents, any thoughts guys.. thanks for any help..
Radios, radio!!
- cb4ever104
Re: Faults with a Ham international Multimode 2
I don't usually work on cybernet stuff , but it seems pretty clear that your VCO isn't locked . You say you changed the crystal board . Have you checked the output of that to make sure that you're getting the correct frequency ?
- Raverrst
- Call Sign: 26LW29
Hi.. haven’t changed the whole board, I’ve replaced the vco, changed capacitor c11 as there prone to fail, checked all the test point frequencies and there all spot on, I’m thinking it’s the pll at fault which I have a spare on the board
Radios, radio!!
- cb4ever104
Was the radio working when it was on 10m ?
- Raverrst
- Call Sign: 26LW29
No, was doing the same with the 10 meter crystals..
Radios, radio!!
- cb4ever104
Well , it's a closed loop circuit . So if you're happy with the 10.240 , Loop oscillator , and the VCO , then I'd try changing the PLL .
Sammy
Sammy
