In my base i allways run a bit higher voltage ab. 15 to 17v so i get more output same input.
My B300p in mobile runs quite hot at full output but it have worked 10 years without any problems.
Zetagi B300P Amp
- Call Sign: 56la422
Re: Zetagi B300P Amp
Paljon pilalle tinailtuja koneita.
What power do you put into the mobile amp pienari ? cheers.
When running a 6 stage amp I always used a low pass filter connected straight onto the amp with a double 259 connector on the rx side,stops the reflective power.
27.555 Usb
27.555 Usb
Harrier push about 12w fm so i can get all out from B300p.
Ok pienari cheers,good swr on mobile antenna helps prolong the life of the amp.
27.555 Usb
27.555 Usb
- Phoenix
Hi there is it possible to post a photo showing us your low pass filter connection Thankyou
26TM114
No,not possible as I dont have the same fitting now.Set up was Radio/3 ft patch lead/rmkl400/double 259 male fitting/zetagi 27 tvi filter/3 ft patch lead//power swr meter/rg 213 to antenna.
27.555 Usb
27.555 Usb
