Colt Excalibur SSB with ptbm059cox Rogerbeep
Hello, I have a question!
How to disable the Roger Beep on the device?
It is always switched on!
Maybe a capacitor remove as with the Hy Gain?
best Regards
Bernd
best Regards
Bernd
Re: Colt Excalibur SSB with ptbm059cox Rogerbeep
Does no one have an idea?
- Mitch
- Call Sign: M1TCH
The 059 board doesn't have a bleep, it must be an addon board. It will usually be one with, or connected to, a small relay and removing the 9v feed from it should disable it. Best I can do without pics.
The perfect face for radio.
- 163TM847
I have never heard of a colt excalibur [silver fronted] with an 059 board all the ones i have seen are PTBM121 which have the Hygain beep
- highvoltageuk
- Call Sign: GM7TMW
Doesn't This radio have the Nato bleep PCMA001S
Colt 1600DX[/color]
- dt307
- Call Sign: 163dt307
Yes lots of people on here know how to do itbernado wrote:Does no one have an idea?
Don't mean to be funny have a bit of respect for all the helpers on here.they don't just sit on the forum waiting to serve you.
Strange you can't even wait half a day for some one to reply before you got impatient......and yet you don't reply to Nick and mich and yet more time has passed .
Let's get back on track
As Nick says they normally a 121 board
Please post 2 good pictures on the inside all the radio not just the board
One component side
One solder side
From this we can tell exactly what board and or sub board and help you further
163dt307-chris
― Albert Einstein
― Albert Einstein
OK i make a Photo from the Colt Excalibur
best Regards
Bernd
best Regards
Bernd
The following boards are installed!
PTBM059COC
PTZZ053AOX
PTSW072COX
PTOS006AOX
Maybe this helps?
PTBM059COC
PTZZ053AOX
PTSW072COX
PTOS006AOX
Maybe this helps?
- Mitch
- Call Sign: M1TCH
The PTZZ053AOX is the bleep board, same as Formac 120 with two small relays, so you could take out a cap or remove the 9v (BAS) feed. I've got the same board in my Concorde Mk1 for the CW but it's wired differently and I haven't found a circuit diagram yet.
OK thank you for this Information ,i will lock later
- Mitch
- Call Sign: M1TCH
I've just found a Formac diagram and it's Pin 5 on the 053 board, looks like TX volts (BT) rather than 9v so I'm a bit rusty, it's been a while. Disconnect Pin 5 and it should stop the beep and delay but still RX/TX properly. Or put it on a switch.
Ok i have found it!
2 caps 1 for the Beep and 1 for the Delay!
Thanks for all!
best Regards
Bernd
Thanks for all!
best Regards
Bernd
- dt307
On the bleep board switch any leg of c6 should do it
Bit late as i think you sorted it now
163dt307-chris
― Albert Einstein
― Albert Einstein
- Call Sign: 56la422
Hi.
I have 2 diferrent Excaliburs.
PTBM058 am/ssb 40ch board and PTBM131 am/fm/ssb 160ch board.
Paljon pilalle tinailtuja koneita.
Mobile. Ham concorde3, Megawatt 4000,Zetagi B550p.
Home. Colt Excalibur SSB , 2el Quad, Diy ldmos amp 1.6kw pep.
Yes many boards were installed!
