Radio cuts out
- Call Sign: 2m0rdg
Radio cuts out
My friend has a superstar SS 6900n radio and the microphone keeps cutting out and DC comes up on the display , has anyone any ideas what the problem can be , rob
- dt307
- Call Sign: 163dt307
Re: Radio cuts out
Problem with supply voltage
Psu under or over voltage
If that checks out ok make sure all connection are good inc fuse.
Can't remember if the under over voltage protection is user config in the menu/software if it is this also may be wrong
What psu is being used ?
163dt307-chris
― Albert Einstein
― Albert Einstein
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: Radio cuts out
Could be an under-powered PSU. If you're running a standard 3-5am PSU it may be struggling to supply on full power. Try running same radio on low power and see if the issues repeats. If not, then it's probably the power supply.
what is the radio rated as putting out on transmit?
