RM Mod 35 transistor replacement ?
Hi guys a friend has this little amp and wanted to know what transistor he could used as it's been marked out.
- 163TM847
Re: RM Mod 35 transistor replacement ?
The manual has the transistor as MOS RM3 [Mosfet] so i should imagine an IRF520 [IRF520N], FQP13N10 should work or even an 2SC1969
There are alot of fakes out there though.
Thanks for the info.Black Spirit wrote:The manual has the transistor as MOS RM3 [Mosfet] so i should imagine an IRF520 [IRF520N], FQP13N10 should work or even an 2SC1969
- dt307
- Call Sign: 163dt307
just changed four rm3 from a kl203p that got 100w up its rear end
i used fqp13n10 as i have lots of them and they are cheap cheap cheap 50p each from a top uk seller farnell
100w out on fm 160w on ssb pep
as the man said lots of fakes i got caught out few weeks ago and killed a cobra 200 lol
163dt307-chris
― Albert Einstein
― Albert Einstein
- radio pete
- Call Sign: 26EY49G7xxx
2SC1969 is NOT a MOSFET it's a standard RF transistor of 16W
2SC1969 NPN Epitaxial Planar Transistor, 27 MHz,
Just changed the old broke transistor for a irf520 and it put out 12 watts for a few seconds and stop working. Was my transistor a fake ? I thought i would get at least 25 watts output ? I was putting 4 watts in.
Can anyone recommend a trust worthy ebay seller that i can buy a irf520 from ?
- listner132
Stay away from ebay if you are wanting to buy transistors unless you are buying from knights or farnell or little diode to name a few..hope this helps.
