Undien 2830 talks to me
- NightProwler
- Call Sign: 163TM186
Righto I got a Uniden 2830 here, The one I ripped the mystery board out of. Anyway it works a treat except when you talk your voice comes back through the speaker, Not a whisper but pretty damn loud. Any ideas dudes?
Cheers...Rich
Cheers...Rich
- radio pete
- Call Sign: 26EY49G7xxx
Re: Undien 2830 talks to me
is this in all modes or just AM ?
- NightProwler
- 163TM847
You can fit a diode and resistor in series to the 1905 audio amp to cut it off during TX,Ive done loads and it works fine.
MOD 3
What mystery mod board did you remove.
MOD 3
- NightProwler
Nice one Nick I'll do that when I got time. Heres the mystery board...
viewtopic.php?f=53&t=53530
No idea what it was or suppose to do tho.
- NightProwler
And what the hell is a Undien anyway?
- 163TM847
Never saw that thread
Only time i have ever seen a 4001 is on an Oscillator board for some Uniden 80 channel radios, And i have a 1750Khz tone burst board here with one on, But they are also used for the UP/DWN mod so the mic buttons dont reset the freq to zero.
http://vss.pl/mods.dk/mods.php3-radio=u ... l.htm#2191
Anyway its gone now and better off too..
If you are a bit dubious on fitting the diode and resistor post a photo [a clear one] of the 1905 solder side and i will make it a bit clearer where too add them.
- NightProwler
Im looking at it now but my eyesight is naff but I can see where they are ok. Next to where that mystery board was there was a relay fitted too but it was wired up to a speaker socket that had been added. I didnt think you needed a relay when adding a speaker socket to them.
- 163TM847
There is info here of using a relay for "talkback" removal, So its possible whoever did the mods had gone by this page.
http://vss.pl/mods.dk/mods.php3-radio=u ... l.htm#2192
- Buick Mackane
Mine talk to me too, They say Why do you keep buying radios you don't need or use ?
- NightProwler
Ahhh I see, Maybe I should of left it in then I will either put it back or do it the other way. Nice one Nick your the man
- astradyne
All the very early Taiwan 2830's/Lincoln's had this issue. No idea whether it was intentional or not, but nobody liked or wanted it and carried out the mods detailed above.
The problem was ironed out with the second run (sound familiar)?
- NightProwler
Just done elimination mod 2 and it works a treat, No more talkback. Nice one Nick
