cobra 200 gtl slide range
- dt307
- Call Sign: 163dt307
might get one of theese in with an issue thats common
its a v2 that you cant get to the zeros but display says you can lol
looked at the schematic and seen hows it done
yes i could play with the voltages or install the missing d321
but the circuit looks to be ok and it should slide ok unless the crystal 10.240 is the limiting factor
any one sorted out one of these before ?? thanks
163dt307-chris
― Albert Einstein
― Albert Einstein
Re: cobra 200 gtl slide range
I think they're cr@p . Sorry . Couldn't help myself .
What's the story with D321 . Why is it missing ?
- dt307
its showing as nc not connected sammy
im sure i can get it going where its ment to just thought i ask before i did any leg work
163dt307-chris
― Albert Einstein
― Albert Einstein
- dt307
i know i can mod it to get it to slide to the zeros correctly its just bizarre the radio will sit with the coarse at 12 oclock and be on say 27.555.00 turn it left and the display will show 27.550.00 but the tx and rx will be on 27.553.00 or 27.558.00 when display shows 27.560 when the coarse is cranked to the right.
163dt307-chris
― Albert Einstein
― Albert Einstein
To be honest I know nothing about them Chris . Does the counter get it's reference signal directly from the VCO ? I'll maybe download the schematic and have a look myself .
- dt307
looks like to be cpu controlled cant see any kind of reference from the vco
i may be wrong but the 10.240 reference for the pll is whats getting pulled by the clarifier
there is feedback from the pll to the cpu it might just compare that and set the displayed frequency.
prob talking through my ass and no nothing about them either m8 or want to...just trying to help a guy out
163dt307-chris
― Albert Einstein
― Albert Einstein
- dt307
no wonder no one wants to work on these radios
imo they are utter crap
she goes to a zero now no probs
163dt307-chris
― Albert Einstein
― Albert Einstein
dt307 wrote:no wonder no one wants to work on these radios
Told you !
So , what did you do to it anyway ?
- radio pete
- Call Sign: 26EY49G7xxx
as a 10m Radio they are fine but once moded to 11m the display goes out of sink the the OSC it's a CPU isue
- dt307
i was thinking to get the display to read better by messing with the feedback to the cpu but not gonna bother.radio pete wrote:as a 10m Radio they are fine but once moded to 11m the display goes out of sink the the OSC it's a CPU isue
it was the 10.240 xtal that was the limiting factor
tryed one from a uniden and was worse
one from an old cybernet worked a treat and got the display to read correct on a zero but is 1kc off on a 5
the owner said he dont care what the frequency shows as long as it does a zero
163dt307-chris
― Albert Einstein
― Albert Einstein
- dt307
update on this bit of tat...
installed a fake mosfet pppppfffffff smoke lol..moving along its mine now.
mosfet in and working damage repaired.
put the frequency back to standard no zeros
audio was raspy distorted and just crap....got a friend to try his exactly the same
looked into them the main pa bias 2sc2290 is set by a resistor and not a vr and its @0.6v this is too low and running in close to class c no wonder it sounds pants on ssb (got that chips frying sound when breathing)
after trolling through about 10 different pa designs for these transistors confirms the resistor value is too high.
added one more resistor in parallel just one i had here and got the voltage up to 0.73v.
result is night and day nice clear audio.
upgraded the power reg as the original was toast due to the mosfet.
just need to sort the frequency drift out as its like raft in the rapids
163dt307-chris
― Albert Einstein
― Albert Einstein
