Any ideas what these add on boards are?
- Avenger
- Call Sign: 163TM122
Any ideas on either of these 2 boards could be, both are fitted to a working Nato 2000.
163TM122 - ROB
- Call Sign: 26TM5890
Re: Any ideas what these add on boards are?
reply on your first picture; if i recall (from memory in the 80s) that could be an better filter?
Elecraft K2
President Grant II Premium
- CaptainKirk
- Call Sign: KIRKY
Top one is an active filter board
CAPTAIN KIRK-26TM013/26CT013/26UK013 John mobile South Cheshire.
- Avenger
I'll have to have a better look at what the varoboard one's connected up to.
163TM122 - ROB
- Newrsoul
The second on vero looks like a logic gate to provide a 10kc shift?
- CaptainKirk
- Call Sign: KIRKY
See if the wires go from the veroboard to a switch and to the PLL then its an Alpha channel mod like the chap said above.
- Avenger
It does,the anl switch is wired between the varoboard and the 02A giving a 10kc jump.theres also a crystal on the back of the switch
163TM122 - ROB
