Make your own CRE8900 programming cable
Otter
Call Sign: 26TM439
Post by Otter » 17 Jan 2017, 17:18
Go on eBay and buy a cheap USB to TTL (5V) RS232 lead.
While you're there, purchase a lead with a USB MINI B plug on it. If this lead has a USB A connector on it too, cut it off.
Wire the 0V on the USB to RS232 lead (usually black) to the black lead in the mini USB lead. (Ground, pin 5)
Wire the TXd on the USB to RS232 lead (usually green) to the white lead in the mini USB lead. (D-, Pin 2)
Wire the RXd on the USB to RS232 lead (usually white) to the green lead in the mini USB lead. (D+, Pin 3)
That's it
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Re: Make your own CRE8900 programming cable
Post by MrWeetabix » 17 Jan 2017, 17:23
we're waiting for the Blue Peter Style 'here's one I made earlier' :-D
porky.69
Post by porky.69 » 17 Jan 2017, 19:10
Otter wrote:Go on eBay and buy a cheap USB to TTL (5V) RS232 lead.
That's it
:thumbup: cheers matey
This is my Territory.....Be on your way 8)
Otter
Call Sign: 26TM439
Post by Otter » 17 Jan 2017, 20:18
MrWeetabix wrote:we're waiting for the Blue Peter Style 'here's one I made earlier' :-D
Well, I did mine slightly differently. I wired it to a USB socket so I can plug an ordinary USB lead into it.It's wired up the same though. It works with my CRE8900.
MrWeetabix
Admin
Admin
Call Sign: 26TM175
Post by MrWeetabix » 18 Jan 2017, 09:17
:clap: :clap: :clap: :clap: :clap:
Looking good :thumbup:
Thanks for sharing with the boards too, its appreciated!
Next up, you have to make one using yogurt pots and PVA glue. I'll have you a TM1 pin badge made up if you can do it without your mum helping :-P
