Audioline 341 help
superstar
Audioline 341 help
Post by superstar » 18 Apr 2017, 18:29
Picked up a cheap 341, was working fine for 10 minutes then went deaf, and no tx, there's squelch noise and channel display is working, hasn't been switched on in years up to now, whad ya rekon guys?
Cb handle
1980-1993, "AL Capone"
1993-present, "Superstar"
ChrisMagpie
Call Sign: 26TM553
Re: Audioline 341 help
Post by ChrisMagpie » 18 Apr 2017, 20:16
superstar wrote:Picked up a cheap 341, was working fine for 10 minutes then went deaf, and no tx, there's squelch noise and channel display is working, hasn't been switched on in years up to now, whad ya rekon guys?
The two dodgy under rated 10v capacitors are the first things to be replaced.
https://www.youtube.com/watch?v=JedRaqYXEyk
Mudslinger
Post by Mudslinger » 18 Apr 2017, 20:53
I had a 345 homebase which had the same thing happen. I am afraid I am not sure what was wrong though, I sent it to Nick who worked his magic on it.
The problem with failing capacitors is that they often cause other components to fail as well.
superstar
Post by superstar » 19 Apr 2017, 06:33
Yeah I've had similar faults on these where there's been no ch display no tx or rx and that was a couple of caps too, I'll see what nick says
Cb handle
superstar
Post by superstar » 20 Apr 2017, 09:23
Above radio going on holiday to wales :)
Cb handle
superstar
Post by superstar » 03 May 2017, 10:39
All done, above radio home and works ace!
Cb handle
ChrisMagpie
Call Sign: 26TM553
Post by ChrisMagpie » 03 May 2017, 14:22
superstar wrote:All done, above radio home and works ace!
Well worth the effort :clap:
jason
Call Sign: 26TM070
Post by jason » 03 May 2017, 19:52
What part was broken ? :)
superstar
Post by superstar » 03 May 2017, 20:05
I can't remember what Nick said it was now but it wernt the 2 usual problematic caps
Cb handle
