Homebase amp help please.
- listner132
Hi guys wonder if anyone can shed some light on the colour code of this burned out resistor on a mates old euro cb ev-200 base amp...
- Dragonfly
- Call Sign: 26TM363
Re: Homebase amp help please.
Will be difficult to find that resistor value as it is a added mod looking at the cut track around it .
- listner132
yip i did nitice that this had been done god knows what for...amp still lights up and valve still glows perfect and still swithching to tx but thats it until i find the correct value of the burnd out resistor.
- andymuza
Why don't you just remove the resistor and bridge the cut track.
- Dragonfly
Or you could try the old valve radio blogs and ask why the end pin on the valve seat would be removed from earth and put through a resistor .
- listner132
thanks guys got amp working fine again..just removed the resistor ans re solderd the cut track thanks andymuzza for the suggestion.
