Yaesu 817 IF tap mod for panadapter?
Posted: 11 Feb 2018, 20:53
I don't know why but I fancy having a panadapter display for my 817.
I've read about it on a few different blogs, and some say to put put the IF signal through a small buffer board like this one https://www.ebay.co.uk/itm/DC-12V-10KHz ... 1438.l2649, but then others are saying just to tap it using a 100pf ceramic cap and a 150 ohm resistor in series. The idea being that you then connect the 68MHz signal to an SDR dongle to use as a cheap 'n' cheerful panadapter.
Has anyone here ever tried this that can offer any advice? Is the buffer board necessary?
https://ve3ips.wordpress.com/2016/08/12 ... -6833-mhz/
http://www.geekshed.co.uk/yaesu-ft-817-if-tap-for-sdr/
