Page 1 of 1
What coax for HF ?
Posted: 23 Oct 2017, 19:54
by gmham
Guys what coax you using on HF ? Looking for around 8 mtrs off RG8 mini. Okay as far losses go on this sort off length and okay for full legal limit power handling ? rg213 is a bit heavy duty on this particular antenna arrangement but would use if necessary.
Re: What coax for HF ?
Posted: 23 Oct 2017, 20:06
by ch25
And full legal is 1500 or.... ?
@28MHZ it would be 0,257dB loss, so no matter.
Posted: 23 Oct 2017, 20:29
by gmham
400 watts... 1500? High power permit, you still get them nowadays?
Posted: 23 Oct 2017, 21:58
by ch25
Depends on country. I can use 1500W legally.
400W is power rg8 can handle. No worry.
Posted: 23 Oct 2017, 22:12
by gmham
Cheers Chris was not too sure but guess especially with it being ssb modes 400w would not be a problem. Not too bad a losses either with quality rg8 mini on this sort off length ?
Posted: 24 Oct 2017, 10:52
by ch25
6 dB is 1s unit, so coax loss mentioned is minimal.
Posted: 24 Oct 2017, 19:12
by gmham
Perfect, quality rg8 mini just ordered. Thanks.
Posted: 24 Oct 2017, 19:21
by ch25
Just watch that video
https://www.youtube.com/watch?v=6e_ppym4yhg
Explains a lot.
Posted: 24 Oct 2017, 20:02
by gmham
Thanks Chris will check that out.
