What coax for HF ?
gmham
Call Sign: 108TM154
What coax for HF ?
Post by gmham » 23 Oct 2017, 19:54
Guys what coax you using on HF ? Looking for around 8 mtrs off RG8 mini. Okay as far losses go on this sort off length and okay for full legal limit power handling ? rg213 is a bit heavy duty on this particular antenna arrangement but would use if necessary.
.... Icom IC7300 HF /6 mtr
Kenwood TR751e 2mtr ssb
108-TM-154 - John
Call Sign: n0call
Re: What coax for HF ?
Post by ch25 » 23 Oct 2017, 20:06
And full legal is 1500 or.... ?
@28MHZ it would be 0,257dB loss, so no matter.
gmham
Call Sign: 108TM154
Post by gmham » 23 Oct 2017, 20:29
400 watts... 1500? High power permit, you still get them nowadays?
108-TM-154 - John
Call Sign: n0call
Post by ch25 » 23 Oct 2017, 21:58
Depends on country. I can use 1500W legally.
400W is power rg8 can handle. No worry.
gmham
Call Sign: 108TM154
Post by gmham » 23 Oct 2017, 22:12
Cheers Chris was not too sure but guess especially with it being ssb modes 400w would not be a problem. Not too bad a losses either with quality rg8 mini on this sort off length ?
108-TM-154 - John
Call Sign: n0call
Post by ch25 » 24 Oct 2017, 10:52
6 dB is 1s unit, so coax loss mentioned is minimal.
gmham
Call Sign: 108TM154
Post by gmham » 24 Oct 2017, 19:12
Perfect, quality rg8 mini just ordered. Thanks.
108-TM-154 - John
Call Sign: n0call
Post by ch25 » 24 Oct 2017, 19:21
Just watch that video https://www.youtube.com/watch?v=6e_ppym4yhg
Explains a lot.
gmham
Call Sign: 108TM154
Post by gmham » 24 Oct 2017, 20:02
Thanks Chris will check that out.
108-TM-154 - John
