Many thanks Drew for your review and many thanks to John for the link, i'm off to click buy it now.
Cheers guys.
A good extension speaker ?
Re: A good extension speaker ?
Got mine also, cracking bit of kit for the money.
- Prostetnic
Hi Guys
Read the review and comments. Bought a pair on Thursday, they arrived and i connected them this morning.
Good speaker for the money and you get two. Need to buy some feet to finish them off.
- ROTEL240
My speakers came today and well worth the money connected them up and they sound good on my 570 dg and look the part, will try them on my optima and they should sound good by passing the small internal speaker. Rubber feet is a good idea and will bring the speakers to the same height as the radio..
Thanks to the GMHAM for the link.......
- gmham
- Call Sign: 108TM154
Great stuff glad you are happy with the speakers. For the money they make sense and again with little feet attached bring them right up to the same level as my ic7300 which is a bonus !
Yaesu FTDX10
Kenwood TS711e
Anytone D578UV Pro+
Moxon antenna for 10/20 mtrs
John - 108TM154 / 108CO154
Kenwood TS711e
Anytone D578UV Pro+
- Auldgeek
- Call Sign: GM0BRJ
Ended up buying a second pair of these speakers to play about with my bhi DSP filter. Best £20 I've spent in a long time!
Auldgeek - Drew
- Buick Mackane
- Moderator
Was browsing the bay when i came across these motorola extension speakers, They are fitted as standard with a 2 pin molex plug, Just a matter of cutting that off and fitting a 3.5mm jack, Just thought i'd mention them incase anybody is interested, I'll be snapping one up.
https://www.ebay.co.uk/itm/Motorola-Rad ... 1438.l2649
- Call Sign: 26SF333
Excellent speakers for £20,got rid of my brand new Yaesu SP20 and replaced with what works out a £10 speaker,sounds much better and £75 back for the SP20,happy days.
