President Jackson 2
A place for new members to say hello and to introduce yourself.
If you're not sure where to post, try here!
Karlbates1966
President Jackson 2
Post by Karlbates1966 » 10 Aug 2017, 20:53
Hi I'm very new to the world of cb and have just received my president Jackson 2 through the post !! Only problem is when I try and set it to the country of origin I:E uk it won't find it in fact none of the options are listed it just shows random letters and always starts with what looks like a fault code like t5 ! Any ideas ? Thanks karl
prettypolly
Call Sign: 26FB185
Re: President Jackson 2
Post by prettypolly » 11 Aug 2017, 10:01
PRESIDENT JACKSON-2
WHEN USING RU-MODE (400CH and Output 15W)
CHANGING BANDS:
-Put Switch
F/OFF
on position
F
-Changing band with rotary switch
-Confirm band: switch
F/OFF
to position
OFF
BACKLIGHT BRIGHTN
ESS REGULATION:
-Normal brightness: Switch on the radio while
DIM/OFF
slide switch set to
OFF
- Dimmed brightness: Switch on the radio while
DIM/OFF
slide switch set to
DIM
Afterwards DIM/OFF slide switch functions as =10KHz frequency shift
FREQUENCY SHIFT + 10KHz
- Change to +10KHz: slide
DIM/OFF
to
DIM
-Cancel to +10KHz: slide
DIM/OFF to OFF
dt307
Call Sign: 163dt307
Post by dt307 » 11 Aug 2017, 15:24
I do a easy mod to use the vox button to switch between ru mode and multi norm
No extra switches and you retain the uk 1-40
163dt307-chris
― Albert Einstein
