Motorola as a DMR Scanner
2wayfreq
Call Sign: Ki6WKV
Post by 2wayfreq » 13 Feb 2019, 20:51
Hi,
Just curious if anyone has successfully configured a Motorola MotoTrbo radio to say, listen to Shopwatch without needing an ID? Where, you can set it to receive "Anything" on the particular Freq, Talk Group ID, Time Slot and C-Code? What settings did you use?
Or, is it better to just get an Anytone DMR radio?
Motorola XPR6500 TRBO UHF
Motorola HT750 UHF
Motorola XTS5000 VHF
GE M-RK UHF
TIDRadio TD-M8 UHF
moj
Re: Motorola as a DMR Scanner
Post by moj » 14 Feb 2019, 01:14
It won't work like a scanner unless it had promiscuous mode built into the radio which it doesn't but the anytone does have that feature so ideal for you !
Metradio
Call Sign: G7HID
Post by Metradio » 14 Feb 2019, 10:53
Be aware, the Anytone will receive any Mototrbo/DMR signal, unless they are encrypted or are using RAS on a CAP+ system..
Mike
2wayfreq
Call Sign: Ki6WKV
Post by 2wayfreq » 14 Feb 2019, 14:52
Aaah, I see. Looks like I'll have to go the Anytone route. Thank you kindly for the replies!
Motorola HT750 UHF
GE M-RK UHF
TIDRadio TD-M8 UHF
2j4ez
Post by 2j4ez » 14 Feb 2019, 20:49
I have the anytone radio 868 radio. If you put the digital monitor switch on and set it to any CC and any ID then you can enter a frequency and press scan button then it will pick up DMR frequencies and decode the audio.
I'm well happy with the radio.
fmdx
Post by fmdx » 19 Feb 2019, 19:44
Hi you can use for example a Motorola dp3400 radio and once loaded up with the correct freqs,cc,slots etc all you have to then do is ensure one of the side buttons next to the ptt is programmed to 'scan' so once pressed it scans through the stored freqs just like a scanner would and with it being a professional radio you will find better quality such as sensitivity etc.
moj
Post by moj » 19 Feb 2019, 20:41
the point me made is he wanted it to be used as a scanner where he could search for frequencys so he would need promiscuous mode built into the radio so the anytone tick's all his boxes .
Metradio
Call Sign: G7HID
Post by Metradio » 19 Feb 2019, 21:50
fmdx wrote:
19 Feb 2019, 19:44
Hi you can use for example a Motorola dp3400 radio and once loaded up with the correct freqs,cc,slots etc ........
Without a scanner - the correct freqs,cc,slots etc - is the problem for most people..
Mike
N1ova
Post by N1ova » 04 Mar 2019, 23:03
The anytone is good, But my local shopwatch Flint,Mold,and Chester are encrypted. I pick the signal up but no voice.
thelad
Post by thelad » 05 Mar 2019, 06:32
Yes i have notice more using RAS and Basic Encryption since the birth of the cheap DMR handys that will work without knowing the TG/CC/SL. Makes it so easy for Joe Bloggs to go shoplifting.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
