Good Afternoon ,
Wondering if anyone can help?
I managed to decode broken signals using a GRE pse 282 on PDw and someone suggested buying a sdr dongle which i did and for some reason i cant get it to work im picking up pagers and getting it into pdw but i dont think the antenna that came with the dongle is upto much has anyone got any suggestions?
PDW and SDR
- MrWeetabix
- Admin
- Call Sign: 26TM175
Re: PDW and SDR
You could buy an adaptor and connect it to an external antenna, just plan it better than my mate did recently haha
- Farty
Re: PDW and SDR
+1 for the above. Get a decent antenna adaptor. I also use a short high quality shielded USB extension so it can dangle down safely out the way.
Re: PDW and SDR
In PDW, what are you getting on the RX levels in the top right?
I find that the volume level is quite critical in PDW compared to other receiving programs.
Re: PDW and SDR
Are you using a virtual cable to pipe the audio into PDW? Have you changed the settings to the cable input in PDW?
