Been away from here for a while but just got a cable that attaches my SDR dongle to my antenna.
Trying to use DSD 1.6 however im getting no where.
Ive read tutorials and watched youtube videos. Have set up SDR# and Virtual audio cables. Yet when I run DSD i get nothing apart from
Digital Speech Decoder 1.6.0 beta with Auto P25 & DMR Filter
mbelib version 1.2.4
Audio In/Out Device: /dev/dsp
Where next?
DSD Help needed
- liamcarbin
DSD Help needed
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
Moonraker Skyscan Mobile Antenna
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
Re: DSD Help needed
Hi Liam, I would strongly advise you use DSD+ with an SDR rather than DSD.
You need to set the radio software (SDR# etc) to output to the virtual cable in the settings, and generally you need to set the VC as your default recording device in Windows (right-click the speaker icon in the task bar and select recording devices). Keep your playback device as your PC/laptop speakers.
- liamcarbin
Re: DSD Help needed
Thanks, just having a play with DSD+ now, this is all new to meAdmiral wrote:Hi Liam, I would strongly advise you use DSD+ with an SDR rather than DSD.
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
- liamcarbin
Re: DSD Help needed
Got it working using DSD+ and SDR# with the DSD+Gui plugin. Is there anyway to mute the radio noise and just have the decoded audio ?
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
Re: DSD Help needed
With the VC installed there should now be an extra option in the Windows audio recording settings called 'listen', untick the box and apply.
- bigbloke
Re: DSD Help needed
If youre using SDR sharp, in the DSDplus plugin you have an external volume tick box and volume slider - untick it for DMR audio only
- liamcarbin
Re: DSD Help needed
Thank you very much.bigbloke wrote:If youre using SDR sharp, in the DSDplus plugin you have an external volume tick box and volume slider - untick it for DMR audio only
Still playing with it. Can only seem to pick up one DMR freq which is the local shopping centre - which decodes quite well. I have a few others but its just showing as data in DSD
Liam Carbin
Stoke-on-Trent
TYT-MD380
Stoke-on-Trent
TYT-MD380
