Hi,
I am having trouble getting the Echolink memories working. I can get into the Menu 204 and add a name to the Echolink memory and add the DTMF code entry which the radio saves. Then it says to transmit an Echolink memory press PTT and press the Tdial and it should bring up the Echolink memory which it does but the name etc I stored isn't showing up ? eg. for GB3BN Echolink repeater I'm entering GB3BN on the name and 1938 for the DTMF code is that correct, what else am I not doing ?
Thanks.
TM-V71E Echolink memory programming
- Call Sign: 2E0SNJ
M6SWA/2E0SNJ
26-TM-4725/26-CT-4724
