Problem With Baofeng UV-82
spoooky
Post by spoooky »
Hi Guys
Im Trying To Get The Uv 82
Working On My Pc
Im Using Win 10 , And I Keep Getting these Messages
This device cannot start. (Code 10)
And In The Device Manager there is a yellow triangle
on prolific USB-to_Serial Comm Port (com2)
iv changed the com port a couple of times
but with no luck
Any help would be welcome
cheers
Spook
26-TM-621
Freddie
Re: Problem With Baofeng UV-82
Post by Freddie »
This is almost certainly a driver problem with the USB-serial converter chip in your programming cable - most of the "Prolific" cables out there are clones which aren't supported by the official drivers.
Have a Google, there are older drivers available which should work, as they don't check if the chip is genuine
Post by Admiral »
As above, you have a Chinese knock off and Windows is installing the latest drivers that won't work with fake chips.
Uninstall the driver and search for driver version 3.2.0.0, it's old, but the only one that will work with the fakes.
Use the same USB slot every time, if you plug it in another one then Windows will again install the latest driver that won't work with your chip.
spoooky
Post by spoooky »
Hi
Thanks For The input
I Tried What You Suggested
But Still Can't Get It To Work
It Comes Up With The Same
Im About to Reinstall Windows As Routine
So Im Going To Try It With Win8
I'll Let You Know The Outcome
Thnks Again :D
26-TM-621
Post by Admiral »
The Windows flavour is irrelevant, you need to use a 32bit system to use the 3.2.0.0 driver, or run a virtual machine session.
spoooky
Post by spoooky »
Admiral wrote:The Windows flavour is irrelevant, you need to use a 32bit system to use the 3.2.0.0 driver, or run a virtual machine session.
Now Its Too Technical for me :shock:
I Wouldnt know how to do that ..im not very computer savvy
26-TM-621
FakeJake
Call Sign: 2E0SEY
Post by FakeJake »
My clone cables work fine in Windows 10 64bit. You just need the old driver from here http://www.miklor.com/COM/UV_Drivers.php
Jake 2E0SEY
Saltney, near Chester (Cheshire-Flintshire border)
Monitoring 2m simplex (when I can)
Dysgwr Cymraeg
spoooky
Post by spoooky »
Well I Reinstalled My Laptop To Factory Settings Witch Has Windows 8 On It
And The USB Lead Is Working Perfect
I Think That I May Have Plugged Inthe USB Before I Installed The Drivers When It Was Win 10
Thats The Only Reason I Can Think Of ???
26-TM-621
wasserbueffel
Post by wasserbueffel »
Windows Update off (not security updates only for drivers).
Otherwise takes Windows again the newer (false) driver.
Interfaces replicas only work with Prolific driver to version 3.2.0.0
Walter
