I'm trying to get a GM340 up and running via computer control.
I've got the audio in via the accessory plug on the back and it all works great apart from there is no CTCSS encode on TX. If I use the hand mic it all works absolutely fine.
Have I missed something in the programming?
GM340 programming problem
- mattltm
"Spooky action at a distance."
Re: GM340 programming problem
Is the unit known to you to be 100% good? Maybe the internal mic is shot?
- LeakyFeeder
The GM series esp the newer.ones have some strange quirks.... Ive got a 660 and 950 both UHF and they.do my head in when it comes to programming..
Just curious as to which mic u using? Gen Moto or an ebay copy?
- StormShadow
Don't use ebay copies there all trash. Use a genuine mic or any other PMR/CB mic
- StormShadow
It can be easy to miss things in the programing? if things work fine with another mic then its clearly the mic at fault.mattltm wrote:I'm trying to get a GM340 up and running via computer control.
- StormShadow
There is a lot of fake Motorola rubbish that comes from china, AVOID.
- mattltm
It's a genuine Motorola microphone and a genuine Motorola accessory plug.
When I use the fist mike, the radio transmits and send the CTCSS tone. When I use the the accessory port PTT and Mic audio in the radio transmits the audio but does not generate the CTCSS tone.
I'm using the radio as an internet connected gateway and it working fine apart from the CTCSS problem. I may end up hooking up an external CTCSS generator to pin 7 and seeing if that works.
