Had one for a week now to play with, battery life seems poor.
Only a day's use or so on RX.
That's a bit crap to me.
Anyone else noticed, or have a I got a dud ?
73 de WNP
MD380 battery life ?
- WhiteNoisePoetry
- 26TM931
Re: MD380 battery life ?
Mine lasts about a week on RX and can get into two days on TX depending on how much transmitting I do !
Sounds like a duff battery (Ever heard of charging it ?)
- zippy
- Call Sign: 26TM537
mine only lasts a day fella, bog standard battery that came with it, not to sure how come the guy above gets a week out of his, and not to sure why he needs to be rude either.
- Call Sign: G4RMT
The capacity of the battery is quite small, and power output reasonable - the two add up to pretty much what you get.
Gentlemen,
I get about 4 days RX only on a reasonably quiet FX. I get about 2 days RX and TX when used in the normal 90/5/5 scenario, high-power setting. Don't forget that the batts may need to be "worked" a bit, similar to NiCD or NiMH before they reach their full capacity.
Rob.
Rob.
- liamcarbin
Two days approx for me
Liam Carbin
Stoke-on-Trent
Uniden Bearcat 3500xlt
Realistic Pro-70 Hyperscan
R820T Dongle ADSB Receiver
TYT-MD380
Stoke-on-Trent
TYT-MD380
- Farty
Is it a new unit? The batteries need to go through a few charging cycles before full capacity is achieved.
- LeakyFeeder
I often left mine scanning 446 and it lasted nomore than a day as its quite busy round here...on DMR scanning maybe a day n half tops...
