I finally managed to re-program my Select-5 GP300 this morning, after all my old computers failed. For reference, the normal GP300 will program fine in modern windoze, the Select-5 will NOT.
I used a virtual machine and a USB serial port; it went something like this:
1: Install VirtualBox, or similar. VirtualBox can be downloaded, or obtained through most (but not all) linux package managers.
2: Find a Windows 98 SE VMWare image from the Net, or roll your own from the Genuine Microsoft Windows 98 Second Edition CD you still have.
3: Configure the VM installation. I also installed the Unofficial Windows 98 SE Service Pack, which lets you unzip things you need to unzip.
4: Go into the VM settings, edit the serial port options. Enable serial port, Com 1, port mode: Host Device. In linux, the port/file path is something like /dev/ttyUSB0.
NOTE: You MAY need to run VirtualBox as root to access the USB port.
5: Install the appropriate software required to program the radio, and run it. Ignore the errors about needing to be run in DOS mode, or similar when you read/write to the radio. You should be able to read/write to the radio just fine via the USB serial which uses the standard port settings, don't mess with them.
Congratulations! Enjoy all the cutting-edge tone features your Select-5™ GP300 provides!
you CAN program that Select-5™ GP300!
Return to “Licensed (Commercial & Imported Transceivers)”
Jump to
- Website Information
- ↳ News & Announcements
- General Forums
- ↳ Newly Registered Members Lounge
- ↳ Datamodes, SDR & other Radio Software
- ↳ Gateway (Internet) Linking
- ↳ Homebrew Equipment Discussion
- ↳ Links
- ↳ Nets and Skeds
- Trading Post
- ↳ For Sale
- ↳ Wanted & Part Exchange
- ↳ Radio Equipment Swap Shop
- Amateur Radio Chat
- ↳ Amateur Radio - General Topics and Discussion
- ↳ Amateur Radio - Digital voice and data
- ↳ Amateur Radio - Equipment Discussion
- ↳ Licensing
- CB & 11m Radio chat
- ↳ CB Radio - General Topics and Discussion
- ↳ CB & 11m Multi-Mode Radio Equipment Discussion
- ↳ CB & 11m Multi-Mode Modification & Repair
- ↳ Tango Mike DX Group
- VHF/UHF Two Way Radio
- ↳ Licence Free (PMR446/LPD433/SRD860/2.4GHz ISM/SRD49MHz)
- ↳ Licensed (Commercial & Imported Transceivers)
- Scanning & Shortwave Listening
- ↳ Scanning Discussion
- ↳ HF & Shortwave Listening
- ↳ Airband Discussion
- ↳ DX TV and Radio
- Scanning Radio Frequencies
- ↳ East Anglia
- ↳ East Midlands
- ↳ Home Counties
- ↳ North East
- ↳ North West
- ↳ Northern Ireland
- ↳ Republic of Ireland
- ↳ Scotland
- ↳ South East
- ↳ South West
- ↳ Wales
- ↳ West Midlands
- ↳ Yorkshire & Lincolnshire
