Does anybody know with listen-only earpieces for GP340s and DP3600s e.g. http://tinyurl.com/lkx5loj
If you can still use the radio's built-in mic to talk, and the earpiece to listen at the same time, like the Police do with their Tetra's?
If not does anyone know of a radio you can do this with?
Cheers!
Motorola GP340 and DP3600 Listen-Only Earpieces
- spencerm
- thelad
Re: Motorola GP340 and DP3600 Listen-Only Earpieces
Why would you want to talk and listen at the same time?
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Binatone PMR MR500 x2
Magiksun TM-490 (BF-888) x3
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- spencerm
Obviously not right at the same time, I mean can you use the radio mic to talk whilst a listen-only earpiece is connected.
- thelad
I have never seen just an earpiece with a mic built in.
Uniden UBC120XLT
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
Uniden USC230E
Uniden UBC3500XLT
Baofeng BF-888
TTI TSC 100R
Baofeng UVB5
Zastone D900
Icom IC-R6
- spencerm
No - a listen-only earpiece, as per the image. With just a earpiece, no mic. Using the radio's built-in mic.
- radiosification
With the DP3600, you can use a normal headset and still use the mic on the radio to transmit. You can set it in the CPS. It can be set to either use the mic associated with the PTT you press, or to always use a particular mic.
Yes with listen only earpieces you can still tx from the radio itself, all you are doing is bypassing the internal speaker and using the earpiece instead.
2M0SRM
Quansheng tg-uv2
yaesu FT-7900E
Motorola DP3600 UHF + VHF
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
Quansheng tg-uv2
yaesu FT-7900E
MTH800
MTP850s
SRH3800
CM-9000
MTM5400
