Programming the Alan HP406 Radio
I purchased one of these radios and programming set, but ridiculously CTE supply a programming lead with an RS232 connector to computer (when did they last have those on a computer?). Please see photograph. I tried purchasing an RS232 to USB adaptor with driver disk, but it won’t programme with that. Are there any of those connectors which actually work (?) or can anyone please suggest another solution? Help!
- B5566
Re: Programming the Alan HP406 Radio
If it comes to com2usb adapters - they does work. It's all about getting them configured right, and by default they are. All you should do is to make sure that windows assigned them as either com1 or com2 as lots of software cant work beyond that . With your programming lead - I presume it's typical primitive rs232 cable so tip and middle ring should have been connected to pin 2 and 3 of com plug while top ring should be connected to pin 5.
Resistance is futile.
Thank you for the reply, I'll give it a try.
- Road_Hog
- Banned
Yep, you need an intelligent RS232 to USB adapter. It isn't just a case of the adapter, but it being able to get the device and the computer talking. Think one is talking Swahili and one Urdu, you need a universal translator.albrecht wrote: Are there any of those connectors which actually work (?) or can anyone please suggest another solution? Help!
I had this problem about ten tears ago, when I was big into unlocking/debranding phones.
I bought this one from Dabs.com about ten years ago and it cost me about £25 then.
http://www.startech.com/Cards-Adapters/ ... ICUSB232V2
The RS232 end, has like half a computer (at least two ICs I can see through the casing) in it, to make sure devices can talk to the computer.
