I bought a Leixen VV808 2m Mobile Transceiver at the at the National Hamfest in Newark (UK) last September but I'm afraid I have not been able to drive it since and it has just sat on a shelf in my shack. I have also downloaded the software for it and bought the relevant cables but I still cannot get it to work. The manual, which is presumably a translation from Chinese, is very poorly written and not at all clear. I should point out that I come from the pre computer era when one button did only one function!
I bought a Baofeng uv-5r about 18 months ago which seems to work on a similar principle to the Leixen but I got that radio to work fine because someone had produced a sample program to upload to the radio. I wonder if anyone has done something similar for the Leixen?
I only bought the radio because of its small dimensions but I desperately need some help to get it up and running. Any Leixen experts out there willing to assist?
Alasdair (M0WAB).
- Call Sign: M0WAB
- dcwuk
Re: Leixen VV808 2m Mobile Transceiver
- Call Sign: M0WAB
Essentially, yes. I am using the hard copy that came with the radio but it's the same as that at <http://static2.rigreference.com/manuals ... manual.pdf>. Unfortunately, I cannot understand it.
I should really like to program up my radio using my PC and the available program but what I need is a partially completed one so that I can see what items go where.
It sets out a list of channels from 01 to 199 which is fair enough. Along the top it says "RX Freq; QT/DQT Dec; TX Freq; QT/DQT Enc;TX Power; Band Width; Scan Add; BLCK; Tail Cut; APRO; VOX; PTT ID; DTMF; CH Alias; Alias Open; Reverse; Talk Around; Custom QT/DQT.
I haven't a clue what 99% of these abbreviations stand for and in order to fill out the table, I need some help.
- Mitch
- Call Sign: M1TCH
Try these...
Rx Freq: = receive frequency (pretty obvious I know )
QT/DQT Dec: = Tone Squelch Decode (receive CTCSS (sub tone) or DCS (digital tone)) needs to be either off or same as TX to receive
TX Freq: = Usually same as RX Freq but needs to be different for repeaters (another obvious one)
QT/DQT Enc: = Tone Squelch Encode (transmit CTCSS/DCS for repeaters and 'private' comms)
TX Power: = Transmit output high/low power
BandWidth: = Receive bandwidth and TX audio (modulation) - Wide is louder, Narrow is quieter
Scan Add: = On is +scan (when scanning), Off is scan skip i.e. misses it out on scan
BLCK: = Won't key transmit when receiving a signal (stops idiots talking over each other or when channel occupied by other users)
Tail Cut: = Same as STE, when 'on' stops squelch crash by TXing for fraction of second after unkeying, only useful if using CTCSS/DCS tones
APRO: = Auto power off (I think) radio will switch itself off after xx minutes of no use or no key presses
VOX: = Voice Operated Xmit (TX), numbers are sensitivty settings for auto transmit (usually off or 0), TX's with voice rather than PTT
PTTID: = Transmit Identification for radio like caller ID on phones
DTMF: = Sends tone codes like phone key pad for echolink and open repeater over IP (internet) type stuff
CH Alias: = Names of channels instead of numbers like GB3xx or PMR-1 etc. (just a guess)
Alias Open: = Dunno but probably related to above
Reverse: = Repeater reverse frequency i.e. TX on output and RX on input freq's (usually easier to set seperate channel rather than go thru' menu though)
Talk Around: = Dunno (try it see what it does)
Custom QT/DQT: = Make your own tone codes up for non standard 'privacy' CTCSS/DCS Note: 'Privacy' means you won't hear others, they'll still hear you if they have no tone code set.
Hope that helps.
Merry Christmas
Hope that helps.
Merry Christmas
The perfect face for radio.
- G0TVJ
- Call Sign: G0TVJ
Just to add to the above, 'talk-around' usually refers to simplex operation on a repeater output channel, so it provides a simplex channel which is compatible with a repeater channel, as long as you're within direct range of the other station and using the same CTCSS/DCS tone as the repeater output.
Neil
SKCC #9547
FISTS #15918
JO01bu
TL42
SKCC #9547
FISTS #15918
JO01bu
TL42
- Call Sign: M0WAB
Thanks very much for your help, folks. I shall now try to program up this radio to see how well it goes.
- Call Sign: m6krm
hi have you had any luck? you may guess i just bought one am just looking into finding a data lead for it.
