Hello - please can someone tell me what setting to use in Chirp to program the same CTCSS code into my Baofeng BF888s for both transmit and receive?
I have tried in the "Tone Mode" setting putting "Tone", "Cross" and "TSQL" but none of these seem to work. The "Cross" setting uploads fine but is then rejected by the phone and changed to "TSQL" setting.
Thanks!
Using Chirp to program CTCSS codes into Baofeng BF888s on PMR446
Re: Using Chirp to program CTCSS codes into Baofeng BF888s on PMR446
I have figured it out - the correct answer is to use "TSQL" and then the radio uses the same CTCSS code for both transmit and receive. Sorted!
the better setting is actually tone not tsql i have a video on my youtube how to program baofengs uv5r uvb6 888s etc look on essexmole and you will find some hd re made videos
