identify these components please
- prettypolly
- Call Sign: 26FB185
identify these components please the two far right resistors and the end component as well please ive found the rest but im struggling with the rest.
- 163TM847
Re: identify these components please
The diode on the right get a magnifying glass and see whats printed on it, The two on the left datasheet below
http://www.st.com/web/en/resource/techn ... 150587.pdf
- Otter
- Call Sign: 26TM439
The two far right resistors are 2.2 Ohm, probably about 2W
- prettypolly
thanks im getting there is the far right a zener diode
- 163TM847
Have a look under a magnifying glass, A zener will normally have for EG: BZ and some numbers to indicate the voltage.prettypolly wrote:thanks im getting there is the far right a zener diode
- prettypolly
Thanks all sorted. Now
