Help needed feeding a quad
- Call Sign: 108SD121
Hi i'm making a 2 ele quad, for 3 or might make a 5 band quad (20M to 10M), but i need advice on the best way to feed it with a low loss feed system. Help needed.
- Black_Pirate
- Call Sign: 26TM034
Re: Help needed feeding a quad
if it muti band I belive its best to use 300 ohm feeder...
its gonna be big....
post a photo...
post a photo...
Didi modes (JS8 on 27.245 usb) txt messages via radio lol at minus- 10 to 20 db..... See FB page...
26T.M.034
GOOD LUCK IN DX
26T.M.034
GOOD LUCK IN DX
Thanks for the info, i don't have any 300 ohm feeder, got some 450 ohm ladder line and 75 ohm twin feeder so i'll have to buy some 300 ohm feeder. I've seen some 300 ohm ribbon cable quit cheap its the lightweight stuff maximum power handling 150 watts so that should do the trick, i'll only be running 10 watts, its a 2 foot boom with the spreaders about 23 degrees, i'll post some photos when its up and running.
Thanks again, MM6SHM Ian.
