John,
Been a while since your last reply on this antenna. Have you managed to find any more information on it? Gain...etc. I still got mine I built last year. I also built a 9 ele yagi. I can try and do some comparisons between them. Also have a moxon I could throw into the mix.
CJU antenna
- thazlett
Re: CJU antenna
TM304
M6THZ
M6THZ
- swizz69
Re: CJU antenna
I fancy a go at a 2m version for Practical Wireless's QRP Contest
Will probably be either walking or pedalling to somewhere - the awkward bit looks to be the loop to make it portable - a full wave loop though should = reduced noise for working weak stations so may be a good trade-off.
@ 5thElement - have you tried yours for anything other than satellite use?
- swizz69
Re: CJU antenna
Found a bit of an explanation in this Pdf on page 3 >>> http://personales.ya.com/ea4cax/paginae ... ingles.pdfI just wish there was more information regarding the theory behind it and why the spacing between the driven element and reflector is what it is etc
It seems that the Reflector acts as a match to the loop, reducing the impedance nearer to 50 Ohms.
Would love to read a comparison. Most of the snippets google throws up suggests it beats a 3 el yagi. I could never get a brilliant match with my 5 el sotabeam copy so am itching to try something different. Being lighter, I'd trust one of these a bit higher up the f/glass fishing pole too.I also built a 9 ele yagi. I can try and do some comparisons between them. Also have a moxon I could throw into the mix.
