new question, help
new question, help
hi all new to this, this is what im wanting, to be able to hear as much as poss, had an icom r20, had a lot of fun on it but now i want to go bigger and better. i want to be able to hear all hf conversations, ssb, am fm,radio stations from around the world, also cb with as much scope as poss. also need info on an ariel. please feel free to suggest as many radios as poss. buget of around ?1000, but can go one way or other. thanks to all. yours matt
RE: new question, help
I would personally say that ?1,000 is too much to spend on a SWL station.
There are lots of very good HF RX's around that will give you everything you want for ?500, if you then add on a long wire & some coax & a Balun to give you an earth at antenna source which will also keep the antenna well away from the house & ?600 would give you a top notch SWL station, in fact you could probably get a very good station on the air for around ?400 all in.
Look on Junksale, they often have good SWL RX's on there.
So I passed this test that allows me to twiddle with knobs, push buttons & call my self an Advanced !!!!!!!
M0LSX
M0LSX
Hi crowman,
As its so cheap ?25 + postage from China, make sure you get a DE1103 as well, to take anywhere with you!
It covers 100kHz to 30MHz AM/SSB and 76MHz to 108MHz FM. Its FM performance is the best I've ever had in a portable.
http://www.transmission1.co.uk/index.ph ... pic&t=6460
Only 170mm x 105mm x 30mm.
Best wishes, John.
Best wishes, John.
Well for a grand I think you could have some fun
How about an AOR 7030 and a log periodic antenna? - does it have to be a receive only station? - i.e. would you contemplate transmitting in the future?
You could then obtain a transceiver, but as well as antennas, you'd be looking at power supplies, tuners, filtering etc.
I'm a little out of touch with the RX scene - have a look in the magazines to see what's being used these days for an idea. What KC says is true. You can do it for a lot less than ?1000, but if you can afford to - go for it
Steve
Click below for further reading/info
http://myweb.tiscali.co.uk/g4ucj/Buying.pdf
Steve
G0SLQ website
Icom IC-7100 + two patchleads and a broken PL
