What station am i receiving ?
mickymcd
Post by mickymcd » 10 Oct 2016, 00:23
I get a continuous transmission I receive on 30.629mhz pretty strong signal its pretty distorted but its befo on the fm mode possibly wide fm which my radio doesn't do to receive It better it sounds like a u.k news service a lot of politics etc :crazy:
Tigersaw
Call Sign: GW6RRL
Re: What station am i receiving ?
Post by Tigersaw » 10 Oct 2016, 00:43
Compare it with a normal FM radio, most likely you will find its radio4 or similar, and it will be an image from internal mixing.
Minus1
Post by Minus1 » 10 Oct 2016, 07:49
If you are using an SDR, it becomes obvious if you change frequency, as the image moves in the wrong direction :-O
