hf frequencies
gerald123
hf frequencies
Post by gerald123 » 16 Jan 2016, 21:52
hi, lads I am looking for hf volmet continuous frequencies if there are any to test my antennas .....I have tried some like..shanwick 3.016--Shannon 5.5048--raf volmet 5.450 and so on ............what frequencies do you listen to.
dcwuk
Re: hf frequencies
Post by dcwuk » 17 Jan 2016, 01:38
I expect you have already looked here. :)
http://www.dxinfocentre.com/volmet.htm
I hear New York and Gander fairly often.
regards
dcw
zippy
Call Sign: 26TM537
Re: hf frequencies
Post by zippy » 17 Jan 2016, 10:25
I use 5.505 usb as a yardstick to gauge conditions around 60m.
Turbo
Re: hf frequencies
Post by Turbo » 17 Jan 2016, 12:09
Hi try to see if you can get these sydney australia 6676,11387 00+30,auckland new zealand 6679,8828,13282 20+50.
Regards Lino.
zippy
Call Sign: 26TM537
Re: hf frequencies
Post by zippy » 17 Jan 2016, 12:59
Turbo wrote:Hi try to see if you can get these sydney australia 6676,11387 00+30,auckland new zealand 6679,8828,13282 20+50.
Regards Lino.
The guy is looking for a signal that's always there Lino so he can tinker with his antennas, the ones you suggest don't fall into this category.
gerald123
Re: hf frequencies
Post by gerald123 » 17 Jan 2016, 14:52
dcwuk wrote:I expect you have already looked here. :)
regards
yes I have looked there .but thank you for reply
gerald123
Re: hf frequencies
Post by gerald123 » 17 Jan 2016, 15:01
Regards Lino.
no I have not tried them but will have a listen for them, but I still need a frequencie that you can monitor at least for 2_3 hours at a time.......if there is any. but thanks anyway.
Auldgeek
Re: hf frequencies
Post by Auldgeek » 20 Jan 2016, 19:45
I always use the German RTTY Weather broadcasts to test antennas and propagation
DDH47 147.3 kHz
DDK2 4583 kHz
DDH7 7646 kHz
DDK9 10100.8 kHz
DDH9 11039 kHz
DDH8 14467.3 kHz
Auldgeek - Drew
Amateur Callsign GM0BRJ
Tango Mike Callsign 108TM144
gerald123
Re: hf frequencies
Post by gerald123 » 20 Jan 2016, 23:48
kilimax wrote:I always use the German RTTY Weather broadcasts to test antennas and propagation
DDH47 147.3 kHz
DDK2 4583 kHz
DDH7 7646 kHz
DDK9 10100.8 kHz
DDH9 11039 kHz
DDH8 14467.3 kHz
ok thank you for that....will give them a try.
