Joint warrior freqs?
punkrocker62
Call Sign: MM1BRH
Post by punkrocker62 »
Hi, I am right next to the Firth of Clyde and the years first joint warrior exercises are under-way, any good freqs for Navy / Air force on exercise? Weekend weather was meant to be sunny, was like pea soup out there :(
http://www.royalnavy.mod.uk/News-and-Ev ... nt-Warrior
Baofeng UV5R / UV5X / UVB5 [Chirp]
NEWSKY RTL2832U / R820T2 SDR >> Ham It Up v1.2 >> [HDSDR]
grahamwilman01
Call Sign: 2E0CSU
Re: Joint warrior freqs?
Post by grahamwilman01 »
Hi Punkrocker
I posted these back in Sept. 2013
http://tinyurl.com/njf34df but I'm sure they are still active around Joint Warrior Time.
punkrocker62
Call Sign: MM1BRH
thank you
Minus1
Post by Minus1 »
Worth searching all the UHF airband as plenty of freqs get used that are silent the rest of the year.
Here's a handful that seem to be used in all such exercises:
269.80000 AM NATO common 'CONSHIP'.
312.50000 AM Royal Navy common A2A A2G.
313.17500 AM Royal Navy — Eagle Safety during exercises.
314.30000 AM rptd Royal Navy FOST exclusion zone. 'simulated guard freq'.
VHF Marine freqs have been used in previous years, esp :71 :72 :15
Also UHF freqs (406–450 range) used on board some ships, but limited range.
Remember that foreign navy vessels may use freqs in unexpected places!
punkrocker62
Call Sign: MM1BRH
thanks
