Advice
andy5600
Advice
Post by andy5600 » 18 Oct 2013, 18:28
Hello all,
Interested in getting into the high frequency band, USB,LSB CW etc for listening/scanning and wonder what sort of kit/scanner/receiver I will need for this?,
Currently I use a PSR-295 for my general scanning use but have been told that this is no use and I would need a long or short wire for for hf?
Would want to listen into raf lossie, sar etc also
Any pointers or advise would be great
andy5600
kr0ne
Re: Advice
Post by kr0ne » 19 Oct 2013, 01:32
I think that's just a VHF and above receiver that you have there, so you will need a new radio as well as a wire (long or short)...
How much cash have you got to spend?
andy5600
Re: Advice
Post by andy5600 » 19 Oct 2013, 08:20
Hi,
Yes, I believe this scanner does not receive below 25mhz
Budget wise i am open to ideas, maybe upto a couple of hundred but not too sure as i am not really familliar with kit in this side of things.
Thanks.
andy5600
JGR
Re: Advice
Post by JGR » 19 Oct 2013, 11:32
If you are looking to cover HF then my personal experience is to purchase a dedicated HF receiver such as the Tecsun PL-660 which performs very well and at a cost of around £75-100, as for the VHF UHF the scanner you have is ideal for anything above HF 50Mhz+ as most of the conversations are in FM.
Long wire antennas can be any length you choose and ideally terminated with a balun to allow the miss-match to be brought nearer to the 50 Ohms, please be aware that a really long length can overload the receiver and the attenuator will need to be used.
Do not believe everything that is in black and white.
Oh and prestigious Winner of "In Before The Lock June 2014"
Flex 5000A, Trio TS-830S, Icom IC-E2820, IC-E92D and a DVB-T SDR Dongle
