FRG-7 RECEIVER
gerald123
FRG-7 RECEIVER
Post by gerald123 » 08 Oct 2013, 19:23
hi hope someone can help.......i have got the abouve receiver ,the trouble is it has a digital readout whitch is not very unstable ...... if i tune to say for instanse 5.680 it hovers between 5.689 and 5.680 and knocks the audio out. {bnghd} very frustrating .... is there eny way i can alter this inside on the main dial ...
normal
Re: FRG-7 RECEIVER
Post by normal » 08 Oct 2013, 20:18
It is a 1970's radio.
Sounds like a fault in one of the local oscillator generators.
Is it unstable on all the 1MHz band segments?
Does the red lock light come on?
Frequency displays are an add-on, is it built into the case or external?
gerald123
Re: FRG-7 RECEIVER
Post by gerald123 » 08 Oct 2013, 23:24
thanks for fast reply...yes it is a 1970 radio it is unstable on all 1 mhz bands..display is in the casing of radio ......thanks ,is there anything i can do.
QRP
Re: FRG-7 RECEIVER
Post by QRP » 09 Oct 2013, 09:41
See if you can have some use of this information
http://www.foxtango.org/frg7/foxtangofrg7.htm
gerald123
Re: FRG-7 RECEIVER
Post by gerald123 » 10 Oct 2013, 21:27
thanks for the info qrp will let you know how i get on........thanks lads
