RTL2832U antenna upgrade advice
Can anyone recommend a what I can do to upgrade the antenna? I understand I need an MCX to BNC cable, would my telescopic handheld scanner antenna be suitable?
- welshevo
- Call Sign: 163TM995
Re: RTL2832U antenna upgrade advice
id say a decent co-linear or a wide band mag mount depends on what your looking to listen too? but for a wide range scanning go with a wide band as these generally go from 25khz too 1.3 GHZ
https://www.amazon.co.uk/Radio-Scanner- ... B0044FTIVY
Tetra is a Lonely place! Get DMR instead! (163TM995) ......
- owza
- Call Sign: M0
Thanks guys. For now I have just ordered a MCX to BNC cable, I will use my handheld scanner antenna, must be better than the one that came with the dongle!
If you want an outdoor upgrade then you will need an mcx to so239
http://www.ebay.co.uk/itm/MCX-Right-Ang ... SwzvlW-Xdu
and I recommend a Watson W-50 aerial
http://www.ebay.co.uk/itm/WATSON-W-50-D ... SwzJ5XUwyw
Its what I am using on my dongle
