Zello Android app.(pTT over GSM)
Re: Zello Android app.(pTT over GSM)
Brilliant stuff, got it now. Thanks for that
Bit late in the night now to try it properly but will give it a go over the next few days. Will give me something to do at work lol.
Are you using android app or pc version?
Edit: Have D/L PC version and added channel on that.
Ham: Yaesu FT-100D, Yaesu FC-20.
CB: KPO DX 5000(V4), TTI-TCB-880.
Scanner: Uniden Bearcat UBC 3500XLT, Alinco DJ-X3, Yupiteru MVT-7100.
PMR 446: Binatone Terrain 550.
26-TM-2407
26-TM-2407
- Call Sign: FRANCISUK22
There is a channel called
Glasgow-Network PMR446 (This rooms just chit chat and theres a few radios linked up aswell)
hotdog and chips - Seems to be very busy in the evenings quizes and is quite a fun room
no passwords in any rooms
also there a repeater link called
K2DES Amateur Radio Link
located USA @ 145.775
but i would only advise to key up if your amateur licensed
Now: TYT UVF1, Baofeng UV-5R, Baofeng BF-888s
Previously: Binatone Terrain 550, Alan HP450
Scanners: ICOM IC-R5 with MRW-210 Super Gainer Antenna - Grecom PSR-282
- radiosification
Not too much too worry about regarding the data usage as it uses quite an efficient version of the speex codec. I don't think this app works over GSM though as stated in the subject. GPRS is the most basic technology it will work on.
It is a very good app though and some people are even using it for 446 gateways because it can be accessed through your phone (unlike FRN.)
I sometimes stream my scanner through zello in the channel "scanner stream"
It's not always on but if you feel like listening you can come in and see if the user "bben951" is on. That's the account I use to stream it.
Just like teamspeak. Not many people would use Zello for digital as of the codec. However teamspeak has a new android app https://play.google.com/store/apps/deta ... amspeak.ts.radiosification wrote:speex codec.
You can pay per slot something like 9p http://www.multiplaygameservers.com/voi ... amspeak-3/ and have a highest quality for Digital but for analog it wouldn't matter.
“Quality: (best quality comes first)
Speex25.9 > Speex19.5 > Speex16.3 > Speex12.3 > GSM16.4 = GSM14.8 > Speex9.3 > Speex7.2 > WinCELP5.2 > Speex5.2 > CELP6.3 = CELP5.1 > Speex3.4
http://www.teamspeak.com/?page=faq&cat= ... are_codecs
- tigerbay
- Call Sign: MW6DZR
Sounds interesting Is there any documentation about how this works and the principles as how it actually "transmits" on the frequencies and how to select them (I'm also supposing that this would be only within the area used by the mobile phone device) I use a mobile internet dongle with 3 and if there is a PC version of this app and how I would go about using it and will it work with the internet dongle? (a download link to this and what requirements I need to make this work would be appreciated)
In a similar vein, 'Serval Mesh' may be of interest. An app that allows voice calls with no infrastructure [ie no access points or mobile network] by putting your phone's wifi into ad-hoc mode. A bit beta-quality at the moment and requires root to run properly. No PTT yet, either.
- radiosification
it doesn't actually use channels or frequencies in a traditional radio sense. It just sends data over the mobile network, just like you would when you view a webpage on your phone, except the data is the output from a voice codec in this case. It just sends it over the internet so you can even talk through your computer on a broadband connection you don't need mobile internet.tigerbay wrote:Sounds interesting Is there any documentation about how this works and the principles as how it actually "transmits" on the frequencies and how to select them (I'm also supposing that this would be only within the area used by the mobile phone device) I use a mobile internet dongle with 3 and if there is a PC version of this app and how I would go about using it and will it work with the internet dongle? (a download link to this and what requirements I need to make this work would be appreciated)
- welshevo
- Call Sign: 163TM995
just on the Zello app on Transmission1 but its veryyyyy quiet on there!! we need to get more users onto this! brilliant app so far though
Tetra is a Lonely place! Get DMR instead! (163TM995) ......
- WoollyMammoth
Just downloaded it, will set it up tonight after work.
Will report back later.
- welshevo
Awesome!!my user name is ajstudiosuk by the way
- radiosification
is there a transmission1 channel?welshevo wrote:just on the Zello app on Transmission1 but its veryyyyy quiet on there!! we need to get more users onto this! brilliant app so far though
- welshevo
yes if you do a search on the app for transmisson1 you will find it
- radiosification
ah found it. But whats the password?
- radiosification
oops never mind, I should have read the rest of the thread
