Jackson 2 best band plan ,standard and export
original45
Call Sign: 45
Post by original45 » 06 Jan 2019, 14:15
Good afternoon all has anyone a excellent band plan for this radio if I'm totally honest I get lost without frequencey counter on display and struggle.
I did download a pdf for plan but it doesn't include things like country of use,power restrictions am fm or ssb .
The radio is moded for export and has toggle on rear on select off on to switch band .
If anyone has a good clear plan can you please point me to it .
Thank you
Stronty
Re: Jackson 2 best band plan ,standard and export
Post by Stronty » 06 Jan 2019, 15:32
I've Never seem a Channel/Freq plan that includes that information against the 400 Ch export plan, sorry. You sound like you have the plan that is correct for the Jackson II, Johnson II, JFK II & Walker. if you combined that with the information provided in the Jackson II Manual you could make your own maybe.
I have included an old list in excel you could amend to suit.
Channel Config Jackson II
original45
Call Sign: 45
Post by original45 » 06 Jan 2019, 16:32
Thank you , that sounds the best idea I guess I have looked neither could I find a good clean one.
I will download print your two you provided and. One for the standard radio. Unfortunantly I neither got a manual or box just the radio ,bracket mike lead so on however it is as new.
Thank you for the PDF and taking time to respond .
Appreciated.
I shall digest the info as I guess output is diff from standard to export ,some channels are repeated on a bandplan I downloaded .
Very confusing .com. Lol.
14CS06
Post by 14CS06 » 06 Jan 2019, 18:29
original45
Call Sign: 45
Post by original45 » 06 Jan 2019, 18:40
Claude thank you ,will print this out too. A quick flick through manual and clarifier only seems to a adjust receive .
That's not good .
slamjam
Call Sign: 26DT871
Post by slamjam » 08 Jan 2019, 21:44
Here's one I made a few years ago when I had a Jackson 2
26DT871 - Ipswich UK
original45
Call Sign: 45
Post by original45 » 09 Jan 2019, 10:50
Thank you that looks great. Nice job. Will print that off tomorrow hopefully.
Thank you
slamjam
Call Sign: 26DT871
Post by slamjam » 09 Jan 2019, 17:57
This is the non Jackson, standard layout I use if anyone needs one - I'm sure there are loads of these online
original45
Call Sign: 45
Post by original45 » 16 Jun 2019, 14:36
slamjam wrote:
08 Jan 2019, 21:44
I printed this off in colour and enlarged it to fill a4 sheet. Laminated it and found it invaluable knowing where I was last night .
Best pj 2 export plan I have seen ,looks the part with the president name on top too.
Thank you for sharing.
Appreciated.
:thumbup:
slamjam
Call Sign: 26DT871
Post by slamjam » 18 Jun 2019, 09:57
no problem. Glad it was of help
