Hi folks,
I recently purchased a CRT SS9900. The radio is performing very well with excellent reports. However I have noticed that the radio has an intermittant feedback "squeal" for a second or so when the squelch is set at 2 oclock or higher with the microphone plugged in at the moment the radio switched on. If the mike is disconnected the squeal does not occur.
Is this a known fault that is common to all of them or should I take it up with the seller? Anyone have any suggestions as to what is causing this issue?
Thank you.
CRT SS9900 Feedback Issue?
- mof000
Re: CRT SS9900 Feedback Issue?
I've never had an issue like that with mine. I've had mine for over 2 years now.
I'm sure others will chime in.
Well, you've isolated the issue to your mic, boom, change it.
